If you draw a triangle and ask Easel to cut on path with a V bit, the preview shows the inside corner as radiused (red arrow). The outside corner is shown correctly (green arrow). You can see a large white space between the two arrows that should not be there.
Is this how Easel actually makes the cut or is this a problem with the preview render.
This should be corrected.
