Hi there! I have a 2-stage project. I have rough-carved the project with ¼" DC bit. I plan on detailing with 60° or 30° V bit. The problem is that it tries to load the detail tool path for simulation or carve (I tried both ways), but it stalls about half way through. Verrrrrry frustrating. I’ve successfully done 2-stage projects before without this issue occurring. Lil’ help! Thanks!
Can you share your Easel project?
I am having the same problem.
Im going to try V, but thats once it loads!
Increase the the total depth of cut and depth per pass if you’re using a vbit.
I’ve been experiencing a similar problem. Go to simulate tool paths and Easel times out. Easel won’t generate a simulation or tool paths if I go to run the project. Seems to be an Easel issue for me.
