"Work Area" Section
On the “Work Area” section of the online tutorials, it shows the 1000mm length maker slides as not already being connected to the Y plane. However, the tutorial has you attach the 1000mm maker slide to the Y axis plates at a very early stage. Should you undo the work of attaching the Y plates to the 1000mm maker slide? Or will the tutorial for attaching the waste board still work with a little logical thinking?
Cancel this question… I didn’t read well enough. During the section for the Y axis plates it says to skip it for the 1000mm kit. Obviously because it is used during the work area section!
