WORK ZERO not working
I have homing switches set up and when I home the machine it works fine I then set up G28 for work home which also works fine, but when I load the file and start to cut it goes back to machine home to start the carve, what am I doing wrong, I am using Picsender
How do you set Work Zero?
G28 is a parking spot (as is G30).
Work zero is also persistent between power off/on cycles and dont require a G28/G30 to be used.
I dont use Picsender so can not comment on that interface.
Thank you Haldor for the reply, I thought G28 was work zero, i have been looking on the forum for something to read on setting up work zero and machine zero, I have tried setting it up on UGCS but get the same results,
Machine home position = your homing switches. This establish a fixed reference point (within the accuracy of your switches)
With a fixed reference point you can have a consistent:
  • Work Zero (Easel Home position)
  • G28 Parking spot
  • G30 Parking spot
  • Work Origin offsets, G55-G59
So a typical work flow will be:
  • Perform a homing cycle
  • Jog to the intended work zero point
  • Probe or otherwize set Z height depending on height of material to be carved
  • Set this as Work Zero
  • Carve
So next time you want to do the same, simply:
  • Perform a homing cycle if you have had power off / disconnect
  • Place material on waste board
  • Carve
Thank you Haldor, that is exactly what I wanted
If you have bump stop/fixture for consistent work zero you can set your g28 above that.
Yes, that is one good suggestion for G28/G30 use.
I use G30 for a raised position close to me, for tool changes.
Thank you Mark, I have fixed a bump stop and set work zero to be above the bump stop, all is working great now
