I have made an design in Fusion 360 which I run through Easel and it cuts to much (cutting on outside). For example there is one shape that should be 56 mm but cutted it measures just 51,5 mm. I have checked the CAD drawing and CAM several times, bit size is correct.
Everything is fine when i draw and cut something in Easel so there is nothing wrong with the machine. So I do something wrong - but the question is where. Any suggestions?
