This is practically a brand new build. Old ShapeOko2 rebuilt from stock, first with ShapeOko2->X-carve, then newest x-carve (x extrusion, x-controller). All wiring is brand new, and properly terminated. Continuity from motor wires to terminal block on x-controller. Spindle is 400w aircooled, running off of separate 48v PSU (controlled via PWM/mach3 controller board).
I just finished the rebuild this past weekend. Everything was working great - gantry trammed/trued, belts properly tensioned, eccentric spacers & vwheels adjusted. Ran the Easel ‘hello world’ first job this morning, with zero problems. Came in tonight to carve some hold downs, and noticed that x and y jog controls weren’t responding.
To troubleshoot, I powered off spindle PSU, and pulled endstop/probe plug block. Re-ran machine setup multiple times. Had same results using UGS.
I’m fairly certain it’s not wiring or motors. Verified on the X - plugged terminal block into Z port on X-controller, and it moved fine (albeit with wrong steps).
Maybe voltage pots on stepper drivers? I’m running the old stock ShapeOko2 NEMA 17’s.
