X-axis judders at certain point
Hi all.
So when moving the X-axis on my x-carve 1000 it judders from 150mm to 300mm whether its cutting or not…
I have loosened the belt a bit, checked steps/mm, boosted the current a little and idler wheels are fine…wth, PLEASE help.
Thanks
Chris
ran calibration, been working with CNC’s for years, used step/mm calculator, and put current pot back to standard as it seemed to make no difference
Ha, yeah I have them set in that area (so much research trying to solve this). Its so odd that it does it only in this certain range tho
done, done and done…even oiled the rails as last resort!
i know, i have covered the trolleys. and mounted brushes
You check rail tolerances? I wonder if you have a slight deform
