When I try to home the machine, the X-axis will move all the way to the left but keeps trying to continue unless I hit the kill switch. The Y&Z-axis works fine. From reading another post and comments, I’m guessing the limit switch isn’t working or is not aligned correctly. Any thoughts on how I can troubleshoot this?
Just go to machine in easel then general settings and you should see a place that shows when the switch is depressed. You should be able to manually press the switch and see if the light turns green. If that works i would say it is not lined up right.
Thank you! Forgot about looking in General Settings. The switch is working fine, so it must be out of alignment.
