X axis moving slowly, Y and Z are fine [RESOLVED]
Hey all, I’m having a strange issue where my x axis is crawling along at maybe 10-15 ipm during cutting and jogging but y and z move just fine. I’ve checked for physical obstructions and reuploaded the firmware via easel. I will also check the terminal connections when I get back to my garage.
Any suggestion as to what might be going wrong?
Thanks!
What are your GRBL parameter values for $100, $110 and $120?
Open Easel, press CTRL+SHIFT+D and type “$$” followed by Enter in the Console window.
The GRBL parameters will be listed there.
$120=500.000
$110=200.000
$100=40.000
$110 seems to have been the culprit. based on this post I bumped it up to 8000. X is no no longer moving at a snails pace. =)
Default for stock built X-carve:
cross post — glad you found it
