X Axis moving twice as far as it should
Hey, guys. My X-Carve seems a little overeager. While the Z and Y axes appear to move correctly, my X axis is moving at double speed. After I set up the X-Carve, I used Easel’s stock Irish knot image as a test cut. I set the design to be roughly 5 inches by 5 inches. However, the image came out as 5 inches by 10 inches. See the photo below. Any idea why it would roughly double the image in one direction?
I’d love any and all ideas. Thanks!
Just a guess, but it could be a difference in settings for the Y vs X motors. One variable is twice (or half) what it should be. Have a look, and if you see a variance then edit it to be the same.
It might be your steps per revolution on that axis are off by a factor of 2.
Can you open Universal G code Sender and type $$ and paste the values back to this thread?
I’m not sure how to do that. I’ve only used Easel so far. Could you point me to the Universal G code Sender?
