I am having an issue with my x axis not consistently traveling smoothly. I was calibrating it this morning after adjusting the pots a couple days ago and now I am intermittently getting issues. It sounds almost like it is not getting enough power, when I was setting the pots I left it on the higher end of the recommended power level and then let it run for five minutes just back and forth no issues.
Then this morning when I turned on the machine I sent a gcode to travel 300mm and it went 295mm and made a sound like it was losing steps, I then sent it back 300mm no issue, back the other way and it went 310mm instead of 300mm. I am not sure what is going on now. I adjusted the pot and wasn’t having any issue with consistency.
I brushed off the vwheels with my shop brush to make sure there wasn’t any dust/dirt built up, but it didn’t seem to change anything.
Any Suggestions would be great.
