X-axis shows switch or homing button pressed in Machine inspector although nothing is connected to these pins.
When you ran through the machine setup, did you specify that you had homing limit switches installed? If you do not have them, run through the setup again and make sure to specify that they are not installed.
I would HIGHLY recommend getting homing switches installed for too many reasons to specify in a single, quick post.
{:0)
Brandon Parker
