X axis travel distance suddenly doubled
I was in the middle of a job and the x axis suddenly doubled in distance and it appears speed as well. Should I just change the $100 to 20? It’s exactly double.
If you double the steps/mm ($100), it will take twice as many steps and go twice as far. You’d want to divide by two.
What machine are you running?
That’s what I meant. Thank you. Just changed 40 to 20 and that did it.
Touched any dip switches recently?
WHY did this happen? Those settings don’t just change.
This will cause you trouble in the future. Only way this works as a correct fix is if you modified your micro-stepping for that axis.
No I have not touched anything. That’s why I’m puzzled. I setup my job. Monitored it for a few moments. Then all of a sudden I heard that something didn’t sound right. When I came back to pause the operation, I noticed that it was off by 1” and it was trying to plunge down to the current level in an area that wasnt cut yet. After moving the gantry, I noticed that it was off.
Have not touched anything. My controller and laptop is down below in a sealed cabinet
There is the chance og something inside the cabinet that have shorted the microstepping switch / malfunctioning circuitry.
I have seen several cases where this was caused by a blown driver chip.
