I have grand aspirations for continuing upgrades on my 1000 mm X-Carve, so I thought I’d start my own thread. I probably won’t be doing anything unique for awhile (if ever), but I do at least plan to document the process for anyone else who might follow.
Current Upgrades:
- 3GT3 9 mm Belt Upgrade Kit for X- and Y-Axes, from tbd cnc (https://tbdcnc.com/)
- Y-Axis 2" x 2" x 1/4" Aluminum Angle Stiffening Brackets, from metalremnantsinc via eBay (https://www.ebay.com/str/metalremnantsinc)
- 3GT 9 mm 20-Tooth Pulleys for Z-Axis Motor and Threaded Rod, from OpenBuilds Part Store (https://openbuildspartstore.com/)
- 3GT3 9 mm 60-Tooth Closed Loop Belt for Z-Axis, from MiSUMi (https://us.misumi-ec.com/)
Planned Upgrades:
- Laser Zeroing System (need to figure out mounting)
- Y-Axis Riser End Plates (will fab my own, will have to replace stiffening brackets)
- Linear Z-Axis (after risers)
After running my X-Carve solely on the weekends for about six weeks and breaking three belts (Y, X, and Z) in that amount of time, the decision to beef them up was easy. I came across Luke’s ad in the Inventables FS&T sub-forum for the tbd cnc kit that comes with everything you need. I went poking around for all of the components myself just to compare, and the tbd cnc kit really is worth buying everything all in one place. Having now installed everything and run a few test carves (primarily for calibration), I would highly recommend the kit to anyone else seeking to perform the same upgrade. I even contacted Luke with a question shortly after placing my order, and he responded promptly and cordially.
I started with my bone-stock 1000 mm X-Carve, sans Z-Axis belt as I hadn’t yet installed the wider pulley for the threaded rod to accommodate the new 9 mm wide belt.
The kit arrived quickly and in great condition in a bubble-pack envelope. In addition to the base kit, I’d also ordered a spare set of belts.
The belts were already cut to length for each axis, and had plenty of extra length. I ended up cutting about 6" off of each one after getting them installed.
For some comparison, the old (left) and new (right) belt clips…
…the old (left/top) and new (right/bottom) belts…
…the old (right - whoops, consistency) and new (left) idlers…
…and (what remained of) the old (right) and new (left) pulleys…
First step was removal of the old belts. In doing so, I discovered a spot in the middle of one of my Y belts with goobered-up teeth. I’ve seen plenty of these type of pics from other members, so I just chalked it up to being part of the club.
I then removed the stepper motors and idlers, and cut the old pulleys off of the motor shafts. I first tried to “punch” the pulleys off using a couple of 2x4’s and a pair of thin metal bars (there’s a video of someone getting them to come off that way), but wasn’t having any success, so I resorted to the Dremel.
I started to re-assemble the X-axis components first since I knew they’d be the biggest pain (I wanted to avoid removing the carriage). This involved very careful use of needle-nose pliers for positioning the nut at the end of the bolt for the idler and spacer, then getting enough threads started to let go of the nut, switch the pliers out for a box end wrench, and finish tightening down the bolt. A healthy supply of patience and judicious application of swear words is advised if invoking a similar strategy. Unfortunately, after completing these acrobatics and getting the first idler tightened down, I discovered that the flanges of the idler were contacting the gantry. I thus removed the idler (removal is, thankfully, much easier than re-installation) and used some 220-grit sandpaper to sand the flanges down. The below pictures show an un-sanded (left) and sanded (right) idler, and the sanded idlers re-installed into the carriage (and just clearing the gantry).
Next was installation of the new pulley on the stepper motor, re-installation of the stepper onto the carriage, then threading the belt. I ground a small flat onto the stepper motor shaft for one of the pulley set screws using a polishing wheel on the Dremel (you can see where I nicked the shaft a little from cutting the pulley off). In order to get the pulley lined up with the idlers, I put the pulley onto the shaft and tightened one of the set screws just enough to hold it in place, then put the motor onto its mounting location on the carriage to eyeball the alignment. There was just enough room to loosen the set screw, slide the pulley along the shaft as needed (it didn’t take much), then re-tighten the set screw. Following that, I carefully removed the motor (with pulley) again, then permanently tightened both pulley set screws. I also used a droplet of blue Loctite on both of the set screws.
For the belt, I highly recommend installing it in the same manner as is suggested with the stock 2GT 6 mm belt in the Inventables instructions - insert the belt down through the top hole in the carriage on either side of the pulley, then thread it under and out past both idlers. I had to use a small hex key to help navigate the new belt under the the idlers.
Before buying this kit, one of the things I’d been concerned with was the lack of belt sleeves for interlocking the teeth and securing the belts at the clips. The new belts’ teeth and width are large enough, however, that a zip tie does just fine.
You can also see in the background of the above picture my professional supervisory team.
I did come to find that the size of the new belt clips eats up a small amount of working area, since the V-wheels don’t clear the clip, and the new clips stick out a little farther than the stock ones. I adjusted the hard/homing stop appropriately.
After getting everything on the X axis installed, I went ahead and fired things up, and used the motor to move the carriage back and forth to either side of the gantry to check the belt tracking on the pulley. I’d managed to pay close enough attention to line everything up, and the belt was riding in the middle of the pulley.
After all that, installing everything for the Y-axes was a cinch. The idlers cleared the Y rails without any sanding, just! A small amount of Y working area was also lost, but as with the X, it’s negligible, and a small price to pay for what I’m getting out of the new hardware. One of the belts here ended up tracking to the outside flange on the stepper motor pulley after I had everything assembled, but I was able to loosen the set screws, use a small tool (hex key) to apply leverage underneath the pulley, and manually move the gantry forward and back to get the pulley to slide out just enough to where I needed, then re-tighten the set screws, all without needing to remove the belt.
After getting all of the electrical re-connected, I used an engraving bit and a ruler to “rough set” the new X- and Y-axes cal factors ($100 and $101 values), then performed a few test carves to fine tune them. My values ended up being $100 = 26.661 and $101 = 26.683 (26.666 is the “ideal” value for both).
One thing I notice, or rather don’t notice, with the new belts, is flex. With the old belts, whenever the steppers would change direction, I could see the belt stretch/flex along with them. There is absolutely no perceptible flex to these new belts.
Using the fish scale method, I tightened all of my belts to 4-4.5 lb at 1" deflection.
I then proceeded to the Z-axis. The only pulley I needed to change out here was the one on the threaded rod. After that, it was a simple matter of loosening up the securing bolts/nuts on the stepper motor to fit the new belt onto the pulleys, then use a small tool to lever the motor out while tightening the bolts/nuts back down.
As the old and new pulleys were both 20-tooth, no re-calibration of my $102 value was necessary (I checked with a dial gauge just to be sure). However, I already have 3GT pulleys for the Z axis in hand, and am just waiting for the 3GT3 closed loop belt to arrive before installing, and that will require calibration. I also managed to strip the hex socket of one of the grub screws on the currently installed pulley, so that’s going to make for a nice speed bump in that adventure.
I’m planning on working on the stiffeners for the next couple of days, so hopefully more details will follow soon!
