When I started a project the bit plunged into the project at home position. I hit the emergency stop switch, I raised the bit and reset the emergency switch. Now when I turn on the controller it does not appear to connect to the stepper motors. The controller is on but no connection to Easel or the motors. I tried turning off the controller, but that did not work either.
I can slide the router along each axis the same way I can when the controller is off.
Do you having homing enabled on your machine? If so, you have to run homing before trying to jog the machine.
Thanks for the reply. I had to take the reset out and clean off the little switch. It was stuck but after a few wiggles and flicks it came all the way out.
