will the x-carve run using universal gcode sender off-line ??
Yes, provided you have the code file (.nc) stored locally.
Thanks HaldorLonningdal…I want to run aspire 8 and universal gcode sender and not have to go on-line…
And I assume that is what you are telling me…and, yes, with a (.nc) file on a thumb drive so gcode sender can find it.
Correct, UGS is Java-based but not access dependant to run / be used with existing file
There is a fantastic search available in the forum.
https://discuss.inventables.com/search?q=Universal%20Gcode%20Sender
