I had a bad carve where elements on my project were misaligned. I heard a vibration coming from the X-Axis that I haven’t heard before. I removed the x-axis housing and lo and behold, the belt was about to break. It has apparently been skipping, which caused the project to misalign. The Inventables shopping tab doesn’t carry the belt for the Pro. I don’t use the machine as much as I hoped, and it is less than a year old with low “miles”. The machine as a 100-tooth, 9mm belt, but the support page lists an 80-tooth, 6mm belt. Has anyone else had similar problems?
