Hi…i hope someone can help me with this. I have the x-carve 2015 model of 1000mm. I start to have a problem cuting a piece that is almost a rectangle i used a whiteside ud2020 1/4" compression bit for cutting 3/4" melamine chipboard. everything is running ok until the cut stars on -x it sees to loose some steps or something because it does not meet with the start point by a 1.2mm difference each pass. i already calibrated the steps on the machine, readjusted every bolt and nut put some locktie where is needed. analyzed the g-code to see if is not a problem there, but nothing. i’m using Vectric Apire with the Xcarve mm Post processor.
thanks in advance
