X-Carve Running Very Slooooow (FIXED)
Update: My feedrate was being capped to 500 mm/min. I changed it to 8000 mm/min max. in Universal G-Code Sender for the X and Y axis. Hope this helps someone else.
Hi everybody. I just finished setting up an X-Carve, however it seems to be running very slow. This happens in both Easel and Universal G-Code sender. Adjusting the feed rate seems to have very minimal effect. I adjusted the voltage for each axis but that seems to have done very little. Any advice is greatly appreciated.
