I have set my machine up. Everything works great. However, when I start carving, it jumps around. I tried to carve a simple dog bone with a name inside of it. It start off great with the little paw print in the corner and the top left hole. Then started the T in the name. It did a small outline and then scooted over a tiny bit and started again. It did the exact same thing for the H. I have no idea what is going on at all.
I will try to add a picture but I do not know how to do so.
It sounds like you might be skipping steps. This can happen if you’re going too fast or too deep (or both), where the steppers just don’t have the torque for it. Try using the Automatic feed and speeds by selecting a Material that is the closest to your material.
You may also want to check to make sure your belts are snug enough and the grub screws on the pulleys are tight and not slipping.
