X-carve halted in middle of job and easel responded that job was done. I assume there was a disconnect of some type. I have tried to reconnect but have had no success. I have the UNO listed under devices as com 3. Should the X, Y, Z lights be on even when not connected to Easel?
Do you manage to solve this? I’m having the same issue now.
Ready to burn mine had for 2 months still cant get it to finish test carve. Replaced usb cable, usb internal cable inside the machine and added a powered usb hub. Guess ill try using it for a boat anchor next
Are you running dust collection that might be causing static?
