Hi @ChrisWundram,
A few questions on your setup if you don’t mind. I have the same VFD and as the directions don’t seem to address the 110 volt version your working system is the best place for me to look.
It looks like you put your input A/C to terminals R, T and E, can you please confirm this? Also for the spindle itself, U, V and W are self explanatory, but for the forth wire did you wire it to E as well? Lastly did you just solder the wires onto the connector that goes into the spindle itself?
Thanks for your help,
Keith
