Hi.
I just upgraded my XCarve to the wide y slide, and X-Controller…
However I had tu turn the power all the way up on the X-Controller pots to make it work since I have NMEA23 Steppers that where originally ordered as an option.
Everything went ok, except that once carving the feed rates keep braking bits. The material is correct, the feed rates on screen seem normal for the cut, but the feed does not seem to match what EASEL says to what the machine is trying to do.
I reduced the feedrates manually to 30% and 50%… But I can’t keep doing this for my carves. I want to know if I am missing something. A setting or something on the X-Controller side of things.
I am cutting Birch Plywood and Easel is setting a feed rate of : 762 mm/min Plunge rate of 228.6 mm/min
Any suggestions?
