I am looking at purchasing a used 1000mm X carve it comes with openbuild blackbox controller, I know very very little about cnc and everything that goes with it, but with the blackbox controller can i still use easel to design everything and send it to the machine?
I assume the Blackbox is GRBL-based, if it is then yes - its compatible
You should definitely be able to. The BlackBox is based on an ATMEGA 328P running GRBL 1.1 based on Open Build’s documentation.
{:0)
Brandon Parker
So did you end up buying the black box? What’s your feedback so far?
