Until recently all was OK and with grblControl I could hit the Home button and the x-carve would go to 0,0,0 using the limit switches. Now it just clicks back and forth a bit (as if it was already in 0,0,0) and that’s it. Not sure why it’s decided to do this. I’ve rebooted, powered off/on, reinstall Arduino drivers but still the same. Everything else works OK - it’s just that it seems to have forgotton how to go back to the bottom left corner and stop at the limit switches.
Anyone seen anything like this before?
Can you post you settings $$.
Settings:
$$ < $0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$100=39.879 (x, step/mm)
$101=39.952 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
ok
Loose wire.
Reconnected and all OK
