X-Controller description
-3 axis design
-(4) 4A stepper drivers (Y axis has 2 ganged drivers for X-Carve type machines)
-Microstepping (Full through 1/16th)
-Easy current adjustment via large, well-marked potentiometers
-Automatic idle current reduction independent for each axis
-Internal 24V 400W power supply for stepper motors
-Large internal heatsink and integrated cooling fan keeps system cool at all power loads
-Spindle speed control (0-5VDC PWM or 0-10V)
-Noise-filtered inputs for 3 axis home/limit switches
-Noise-filtered input for Z probe/touch plate
-2 digital outputs to control external items like vacuums and coolant systems
-All inputs and outputs have their own ground terminals for clean and easy wiring.
-Labeled connections
-Rugged latching E-Stop that kills all power
-Feedhold, Cycle Start and Reset (Motion Cancel) buttons on front side
-All electrical interfaces use large, detachable terminal blocks
-USB connection
-Heavy aluminum chassis with mounting holes
