Everytime I do an outline for a piece my machine just stop after seconds of cutting
Some more detail would help.
Does it aslo stop if you run the cut file in air? As in with spindle = off and no stock to carve in.
I am using easel and this isn’t the first time this has happen to me. It seems like, it only happens when I try to outline something. Sometimes it runs for 5 minutes or 10 sec and then machine just stops. I tried and run it without the spindle on (I am running a Makita router instead of the dewalt) and it seemed to work perfect but. Other threads say it could be the usb port is under power but I have run the fill command instead of the outline command and seems to work perfect. So I don’t get it.
When my brushes were worn out in the router (dewalt) the electrical noise was actually tripping the homing/limit switches.
So what is easier getting a new router or just get rid of the limit switches, they seem like they are cheap and break on me all the time.
I replaced the brushes in my router…quick and easy
I later on replaced the switches with magnetic hall effect switches
So for right until I get replacement brushes if I unplug the switches it should run correctly
