X-Controller PWM output voltage
I am interested in using the X-Controller PWM output to control my spindle and dust collection system. Does anyone know what the output voltage is when you set up the X-Controller to control the spindle? Hard to but a relay of you don’t know what voltage you have to drive it.
Max voltage of 5V.
The Xcontroller’s 0-10V output is a “filtered” output up to 10V.
I’ve just wired my spindle and dust collector using two separate relays. Look here for wiring.
@RichardWalker
You need to make sure that you draw less than 40 mA per logic pin from the X controller.
