Hello,
So last night my X-Controller rear fan finally died. I have been trying to find a replacement on Amazon hoping that I can get it quickly shipped to me as my machine is down but haven’t been able to find one that is the correct size and voltage. I was hoping that someone else has had to replace it and can suggest a good replacement. Thank you for any help or guidance you can provide.
Tyler
what is the size and voltage you are looking for?
It looks like it is 40mm x 40mm x 15mm at 24v DC.
looking at walmart, newegg, amazon etc. they are all sold out. man there must be something going on here. Could you not get one that is 10mm thick so that you have some cooling until they get back into stock?
Maybe even a 20mm thick fan would work as long as it doesn’t interfere with anything else on the inside. Even a thinner one, as mentioned, as long as it produces roughly the same CFM or more as the original.
{:0)
Brandon Parker
I wonder if you can put a home box fan behind it force some cool air through it?
