I must have missed the Z zero set up while installing my new X-Controller. Thanks to Kenneth Connell for giving me the information I needed to properly set up my “Z” probe. Don’t know why this isn’t spelled out in the install instructions from Inventables? Just in case you missed it also, here it is:
Go to the easel set-up page and when you get to the touch probe part there is a field for (advanced) when you click this advanced button during set-up you will see an option to specify the thickness of the touch plate you are using. measure your touch plate and input that measurement in the field. this should ensure that you are probing at a specified thickness of your touch-plate.
There you go, should work for you as it did for me.
