came out this afternoon turned everything thing on and the X axis does not move .everything else works. Thank-you
If you connect X-stepper to Z-driver output, does it (X) move then?
If so, X-driver is toast.
i put 2 new steppers X will not move in jog i can push it and theres is no hold back
Did you connect Z wire to it and still try to jog X?
You would have to jog Z.
Just making sure you understand.
- Disconnect from the controller your known good Z-stepper
- Connect your X-stepper to Z-driver output
- Attempt to jog X, does it move?
If it does not move, it strongly suggest your X-driver chip is toast and need to be replaced.
Sorry I made a mistake. It’s the Y axes I think it’s the PCB.
