Why does my x stepper motor loose it’s lock periodically. Like once every project. I am tired of loosing projects
And $1 is set to 255 and the dip switches are set to provide full power?
also check belt tension
I have checked all those points. I changed the stepper motor and seen one of the pins I. The connector was discoloured and I loosened all the wires to the x axis motor at the controller and re tighten them it seems to be holding now but if it looses traction again I’ll be lost
