I there,
first of all, thank you for your precious time.
So here is my current situation …
initially everything was fine about my set up and machine.
I run a MacBook Pro 15" 2015 ( Sierra )
I got a GRBL 3018pro with an extra offline controller
before my issue, everything worked pretty well with the controller.
but when I tried my first test of the CNC, it seem that in easel the spindle did not spin when easel launched the carving session.
So I tried few basics possibility : turn off and on , Reset button , unplug and plug the X,Y motors …
and after that without knowing how i did it …
the spindle and the Z axe finally worked …
but this time this is the X and Y axes that doesn’t work at all … no matter how …
same situation offline with the controller even after Reseting few times.
each time I use the controller after a reset.
the spindle and the Z-axes works very well, and when I try the X and Y axes everything bugging.
when I try the X and Y axes the spindle and Z axe doesn’t work anymore …
I already try to switch X and Y to see if it work.
and there is a possibility that I accidentally plug the offline controller while the USB was plug on the macbook but anyway … I can not think this is a big issue …
but I didn’t find any youtube video or topic of the same problem …
thank you again if you can fix my problem !
