Does anyone know how to fix a problem with the x/y axis, when pushing forward the left side goes forward and the right side goes backwards.
I have everything els working.
Newer XCarve with XController or older model?
In the wiring instructions for the XController you have to reverse the wiring on the Y2 motor.
Here is the description:
With two motors on the y axis facing each other, you’ll need to flip one of the y pairs for the motors to move in the same direction. The diagram above shows the black and green wires flipped on Y2.
Thank you I got it fixed, that was the problem. Now I have a new problem…
And what is the new problem, I’m sure someone here can help out
