None of my axis’ are moving when I try to set up Easel. Easel says to test each axis, but where do I do that? I don’t see where I can do that. I checked all the wirings & the correct wires are connected securely to the correct areas. Help!! -Anita
Make sure you have the Emergency Stop button pulled up all the way, turn it and pull it up.
Russell
Do you hear the machine make a minor “jolt” sound when its powered up? The stepper drivers energize the steppers and this make the steppers lock onto its nearest step position. This create a minute jolt motion/sound.
If you dont notice anything, its possible that the drivers dont receive power.
One culprit may be the E-stop, it need to be firmly disengaged (or bypassed entirely while troubleshooting)
The E-Stop button is up. It sounds like it jolts slightly. Nothing’s moving.
Ok, drivers energize thats good.
Next would be to check and verify the integrity of the wiring of the steppers themselves.
Snap a pic of the controller front panel/wires?
For some reason it just started working. Dunno how or why, but IT’S ALIIIIIIVE!!!
