I have had problems with my 3018 pro not lasering now I try to carve and the controls are in reverse. I used to have a setting to correct this but not on the machine now. any help please. kas
You can redo the easel setup. There is a screen it has you test each axis and answer whether its moving in the correct direction or not…by answering these quetions easel will automatically change the $3 setting for you.
Or you can manually change the $3 within easel by going to the machine inspector (press ctrl+shift+D) and scroll to the bottom to read the current setting, then use this table to determine the correct value, go back to the top and send the new setting,…
