I’m selling my XCarve 1000mm after a few months of ownership. This machine works flawlessly but just don’t use it enough to justify the cost. Below is what will be included plus the 1/4 bit set for V-Carving and the carving bit super pack. I’d be willing to meet the purchaser half way depending on where you’re located. I’m in South West Indiana in Evansville. Asking $2,200 but willing to work on that number a little bit.
X-Carve Upgraded X-Carve Core Components Makita Router Makita RT0701C X-Carve Makita Spindle Mount Mount and hardware for Makita RT0701C 1000mm X-Carve Modular Waste Board Kit Full Waste Board Kit Makita Router Collets Collet Size: 1/8 in Collet X-Carve 1000mm Rail Kit Black MakerSlide, support extrusions, brackets and hardware Easel Pro Membership Duration (months): 36, Qty: 1, Type: Individual X-Carve Drag Chain Kit 2 drag chains + supports and mounting hardware X-Controller Kit Type: 3D Carving Motion Controller Z-Probe Z-Probe Kit X-Carve 1000mm Side Board Kit Side Board, extrusions and hardware X-Carve Dust Control System 1000mm Dust Control System. X-Carve Homing Switch Kit 3 homing switches, 3 cable assemblies + mounting hardware X-Carve Upgrade: 9 mm Belt and Motor Kit Contents: 9 mm belt, 3 upgraded motors, 9 mm idlers, belt clips and sleeves X-Carve Upgrade Kit Contents: Direct Drive Z-Axis, 2" Risers, and Stiffeners X-Carve Toolkit Includes 7 piece metric hex key set, 2mm slot head screwdriver, 7mm, 8mm, and 10mm open-end wrenches, safety glasses, all in a black pouch X-Carve NEMA 23 Cable Subassembly Cable assemblies for the NEMA 23 kit Clamp Set for 3D Carving Includes bases, boosters, arms and screws to clamp materials up to 1.75" thick. Digital Calipers Easily measure the exact thickness of your material X-Carve Packaging X-Carve Main Shipping Box Pre-Assembly T-Slot Nuts Quantity: 14, Thread Size: M5 (5mm) × 0.8 Button Head Cap Screw Length: 12mm, Pitch: 0.8mm, Quantity: 16, Thread Size: M5
