I am selling my 750mm x 750mm xCarve in Olympia, WA fully assembled and lightly used.
I also have a collection of drill bits and some materials I’m giving away with the machine (some wood, one acrylic sheet, two aluminum sheets).
I originally bought it for my business and ended up not using it as often as I hoped. Machine works great, we have one honing switch that is a little damaged but still works and a few cuts made in the wasteboard.
I was hoping to get $1500 for everything included below:
DRILL BITS / MATERIALS
Solid Carbide - Fishtail Spiral, Upcut Bit - 1/16 in D - 30423-01
Solid Carbide 2 Flute Spiral Upcut (Ball Nose End) - 26015-01
1/8” Bit Set for V-Carving - 30784-02
Carbide Tipped Single Flute Straight - 26000-01
Solid Carbide Single Flute Engraving Bit (1/4" Shank) - 26007-01
High Speed Steel Single Flute Upcut Spiral - 26004-01
Solid Carbide Ball End Mill - 30240-02 (×2)
Solid Carbide Single Flute Engraving Bit - 30499-01 (×2)
Solid Carbide 2 Flute Straight End Mill - 30237-02
Aluminum Sheet 6061 - 24800-22
Black Anodized Aluminum Sheet - 24908-06
Silver Mirrored Acrylic Sheet - 24135-03
XCARVE - ASSEMBLED
X-Carve 750mm Waste Board Kit - 30702-03
X-Carve 110V DeWalt 611 Spindle and Mount - 30622-06
X-Carve - 30686-04
X-Carve Drag Chain Kit - 30771-05
X-Carve 750mm Rail Kit - 30688-03
X-Controller Kit - 30618-06
X-Carve NEMA 23 Kit - 30773-05
Z-Probe - 30611-02
X-Carve 750mm Side Board Kit - 30705-03
X-Carve Dust Control System - 30740-03
X-Carve Homing Switch Kit - 30772-05
Easel Pro Membership - 30788-01
X-Carve Toolkit - 30540-02
Clamp Set for 3D Carving - 30675-02
