I have a Xcarve that was previously set up without any issues. However, I thought an update to my computer wiped it out and I am attempting to set up the machine again.
When I go through the set up process, the X.Y, and Z directions work correctly. However it starts the homing sequence to the back right and not the front left. I changed the machince inspector setting from $23=3 to $23=0 and it corrected the homing sequence to the front left.
It then will complete the homing sequence without issue.
However when I try to start carving the machine tries to push forward past the home position. When I cancel the carve the machine reverts back to a new home position that is about 12" inches behind the origianl correct homing position.
Any thoughts?
If I change the $23 setting from 0 back to 3 it will cause the homeing sequecnce to revert back to the wrong direction.
I attached the video to show the issue that is happening.
