What causes the X controller to lose connection with x carve?
In the middle of a project in Easel.
Usually it is caused by either power drop-out on the USB line or electrical noise picked up by the system.
Try a powered USB-hub and connect to that, make room between power cables and signal wires. Fluorescent lighting can produce electrical noise, household appliances can also do that.
okay thanks. I will give that a try.
Also your computer might be timing out the usb to save power.
Thanks , I checked settings and everything is marked never sleep.
This just started happening on this project.
