New to the forum. Have been using Easel with my 3018PRO machine - works well without issue.
I am about to have access to a 1000 x 1500mm machine and wanted to connect Easel to it and execute some of my current designs.
The CNC has an XPro-V5 controller connected to a 1.5kw water-cooled spindle. I believe it uses standard GRBL g-code files.
Does anyone have any gotchas or issues that I may encounter in making this work? I have access to setup macros which are used in CNCjs, do I need the same settings for Easel?
Thanks.
Just export the gcode from easel and use cncjs to control three machine and run the job.
I would not try to connect through easel.
