XY starting position
I am new to CNC and EASEL. Have many years experience with Lasers and Ligtburn.
I am having difficulty with the origin. I move the spindle to the location I need and set the CARVE to use this position. However, when initiating the cut the head moves to another location.
I don’t understand. Not what I am used to. I want the cut to begin exactly where I set 0,0. In this case the lower left corner.
Clearly I am missing something.
Do you have home switches? If so, you can home it and it’ll move to the lower left corner if set up correctly.
Then there is this:
