Y axis move only 300 mm
hi
I have xcarve 1000 mm
When I have a bigger project more than 500 mm
The y axis stop at 300 mm distance and continue from that position
Did you change your machine setup to reflect you have 1000mm X-carve. By default its set to the 500mm if i remember correctly.
Yes all setup for 1000 mm
The x axis works fine
