I’m a complete greenhorn when it come to the x-carve (500mm). I have had a good 3 solid runs, but as you see in my latest run things are no longer running smoothly. The Y-Axis seems to be off by around an inch. The machine is running smoothly and seems to be working correctly-ish. Just need some insight from a veteran maker community. Thanks again and I look forward to hearing from you all.
+1 on what Aaron said. Also, make sure you pot up your Y axis current on the gShield. Most everyone has to do this. Search for Y-axis current adjustment and you’ll see much information on it.
