my Y drive on my CNC3-3018Pro does not move the table forward or backward. I checked to make sure it wasn’t too tight. What do I need to do?
Swap the connections between the X and Y steppers. If the problem then transfers to the X stepper, the Y axis driver probably needs to be replaced. If the drivers are not individually replaceable, then the whole controller will need to be replaced.
Edit: Depending upon the board you have, the individual stepper drivers may be replaceable. Suggest you contact the seller if you determine that you have a bad driver or board, and not a wiring problem.
I did that. Control board was bad. Got it replaced and is working fine. Thank you for your help.
