Y moves the wrong direction during homing sequence
The z limit switch works perfectly, and then the x homing switch works perfectly, but the y motors move the wrong way (they move smoothly, just in the wrong direction). Only the setup, theres a button that says “Change setting for homing direction”. I click that, and run it again, and nothing has changed. It does not give me an option to select which axis is going the wrong way.
my settings are as follows:
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
$132=100.000 (z max travel, mm))
You need to check your wiring of the Y axis.
The grbl parameters look good.
