When I tried to use Easel for the touch plate, I had to do my final move command and workplace zero-ing via Easel itself.
Whenever I tried to zero via G92, I experienced similar to what you are seeing. However when I used Easel to lower the bit and zero the stock, it worked properly, all the time.
