Hello - New Here, But I did spend a good amount of time trying to find a topic to help - I feel I might not be alone on my issue and hoping it’s an easy fix -
So, If I’m cutting ANYTHING, as the Machine moves more and more right the depth becomes increasingly off. For instance, I cut out the Letters for the name JAMES - Starting Pretty Far left, the “J” Cut out Perfectly, even slightly attached to it’s tab - Then Moving right the “A” not so much, and got worse and worse. Till you get to the “S” I was barely able to Pop it out but have to Sand the entire letter.
I put a Square up on my X-axis rail Far Left its at just above 3 1/8" to the bottom of the rail and looks the same to the very far right. So Im Assuming My x-axis is square to my waste board?
I Have removed the Z-Axis and router, loosened the bolts, and tightened and Calibrated the best I can, and squared up that to the waste board several times, but still getting this issue and I have no idea why.
Again new to this, but actively trying to find a solution - any help would be amazing. Thanks in advance.
