When I’m cutting with a 1/2 inch MDF board directly on the waste board the z-axis starts out at the correct depth then starts cutting above the workpiece about 2 inches away. This issue does not exist when I stack two 1/2” MDF boards though. I ran the test calibration pattern to almost perfect depth across the whole cut when the board is raised that extra 1/2”.
I see that $132 is set to =100 .
I’m not sure why inventables isn’t pushing this change to the machine with all of the others for the upgraded Z… it is supposed to be $132=152.5 and that WAS part of the manual steps before they made it automatically push the settings to the users machine… Although this shouldn’t have a real issue since your limits are actually turned off by a different setting in there.
No everything looks correct… this is the new version.
With the linear rail z and makita router, right? I was assuming yes based on the post subject, but wanted to double check
