I’ve had problems recently with movement on the z-axis: example, across a 200mm horizontal pass of 1mm depth, the router bit rose 0.25mm.
I noticed the flange bearing has some vertical movement. Is this normal, or have I found my problem?
Video (4 sec) shows movement when spindle pulled up and down with fingers - sorry for the shake on the camera hopefully doesn’t obscure flange movement.
I think that should be solid and not have that sort of movement… you could call up inventables and ask how much $ the part is … Here’s their part number for reference
Thanks Cmckercher,
I tried after I saw your suggestion but the collar is already tight against the inside radius of the bearing which still allows movement.
